I need some kind of wifi adapter, and im not sure what to get. I know the PCI adapters are better than the USB adapters, but does it matter which one i get? Like, if it is somewhere between 30-60 dollars it is probably just fine?
CPU i7-9700K @ 5 GHz Motherboard ASUS ROG Strix Z390-F RAM Corsair Vengeance 32 GB (4x8) 3000 MHz GPU ASUS RTX 2080 ROG Strix OC x2 SLI Case Corsair Graphite 780T Storage 256 GB Samsung 860 EVO, 6 TB Seagate Barracuda PSU Corsair HX1200i, 1200W Display(s) ASUS PG279Q (1440p 165 Hz), ASUS VG248QE (1080p 144 Hz) Cooling ASUS ROG Ryujin 360 radiator Keyboard Logitech G710+ Mouse Logitech G502 Sound Logitech G35 Operating System Windows 10
https://linustechtips.com/topic/284346-need-an-wifi-adapter/
I've found TP-Link PCi cards to be fairly reliable and with good throughput in the past, cheap & cheerful :)
USB Sticks have always had worse signal for me, unless you get one with a proper antenna on it, not a micro one.
Cartman - AMD Phenom II x6 1055T 3.1Ghz - 10GB Ram (Mwahahah) - 256GB Crucial MX100 Boot - 2TB WD Red - Gainward GTX 770 - Zalman Insanely Loud CNPS14X - Corsair 230T Orange
Stan - Intel Pentium G3320 - 8GB Ram - 128GB Intel 520 - Raid 1 6TB WD Reds - Bit Fenix Prodigy
Kenny - HP 14 Ultrabook (No name apperently) i3 4130 - 128GB Intel 520
https://linustechtips.com/topic/284346-need-an-wifi-adapter/#findComment-3859642
