I keep losing Adobe Flash Player
Go to solution Solved by techenthused73,
Ran into the problem again.  Removing the registry entries with Revo seems to have solved it.
Hi,
I seem to keep losing Adobe Flash Player extension in Firefox or it gets corrupted.  What happens is I'll go to Pandora.com or YouTube and the page hangs and locks up Firefox.  Uninstalling and reinstalling fixes it for a while but then it will stop in a few days.
Have tried the uninstaller from Adobe and it does not solve the issue.
Thanks in advance.
CPU i7 4790 | Motherboard  ASUS Z97 Maximus Hero VII | RAM 16 GB Trident X @ 2400 Mhz | GPU Titan X | Case NZXT Phantom 530 | Storage Samsung EVO 840 1 TB SSD, 2 Seagate 150 GB HDD, 1 External 3 GB Seagate HDD | PSU Corsair HX 1050 | Cooling Zalman Copper 2 ball | Keyboard  Logitech G710+ | Mouse Logitech G502 | Sound: Creative Z | Operating System  Windows 10
https://linustechtips.com/topic/284258-i-keep-losing-adobe-flash-player/
One of the reasons I ditched firefox.
Try completely uninstalling firefox and starting from scratch?
(Also Chrome and it's autoupdating flash for zee win!)
Cartman - AMD Phenom II x6 1055T 3.1Ghz - 10GB Ram (Mwahahah) - 256GB Crucial MX100 Boot - 2TB WD Red - Gainward GTX 770 - Zalman Insanely Loud CNPS14X - Corsair 230T Orange
Stan - Intel Pentium G3320 - 8GB Ram - 128GB Intel 520 - Raid 1 6TB WD Reds - Bit Fenix Prodigy
Kenny - HP 14 Ultrabook (No name apperently) i3 4130 - 128GB Intel 520
Hi,
Thanks for the replies.  I downloaded Revo uninstaller and did the uninstall that way.  It found registry entries but I missed how to remove those.  I had it remove all the folders for Flash.  Hopefully that will do it.
  • 4 weeks later...
