I'm kind of thinking about buying some custom sleeved cables for my EVGA SuperNOVA NEX 650 G1 and would like some suggestions for cables for it. I am thinking about getting black and white ones to go with my black S340. I have a budget of $90. I was thinking about getting a second SSD, but I really don't have a reason for one. Some options would be great. Thanks. :D
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/283746-sleeved-cable-suggestions/
Get the 24 pin for the Mobo and the 6 or 8 pin needed for your Graphic card(s). You won't see the CPU Cable located at the top of the Mobo, unless you have a full window side panel. I wouldn't recommend to buy this one.
Also if you buy extensions instead, take in consideration the length for the 24 pin. just to make sure you can hide it behind the Mobo. 18 inches is long, a 8-10 inches will be enough.
FrozenCPU has lots of option. check it out.
