Hey. I need some help with a case choice.
I don't care about looks. My main choice is cooling and it it looks good, It's just a perk.
I've narrowed it down to two choices.
http://www.novatech.co.uk/products/components/cases/cases/cas-732.html
and
http://www.novatech.co.uk/products/components/cases/s210-001.html
The NZXT one is more expensive and only comes with one fan whereas the Novatech one comes with 3 fans already included.
Do I really need more than 3 fans?
https://linustechtips.com/topic/283437-help-with-case-choice/
Wow I see you have a really low budget, maybe if you want to spend a little bit more go with something like the NZXT S340 it's cheap and looks pretty damn good in my opinion.
MY COMPUTER-
Motherboard: ASRock B85-M Pro 4, Graphics card: MSI Radeon R9 280 Gaming 3GB, CPU: Intel i5 4590 Stock Cooler, RAM: 8GB Corsair Vengeance, Case: My Beloved Phanteks Enthoo Pro :wub: PSU: Cougar PowerX 700W Storage: 1x Segate 1TB 1x WD Blue 250GB 1x WD Blue 350GB, Wireless Adapter: TP Link WN881ND, Monitor: BenQ VZ2350.                      To Learn how to troll, Click here
https://linustechtips.com/topic/283437-help-with-case-choice/#findComment-3847376
OP doesn't care about looks.
Go for the Nova case, it has unrestricted airflow and while it may be the 'gamer' crap that most of us guys here don't like too much, It'll keep your system running cooler than the NZXT Source.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/283437-help-with-case-choice/#findComment-3847390
Thanks. It doesn't look too bad and I don't think I really need anything more than 3 fans. I don't want my PC to turn into an air mover.
https://linustechtips.com/topic/283437-help-with-case-choice/#findComment-3847406
I've got 8 fans in my system (2 on Radiator / 2 in front / 1 in back / 3 on GPU) and it hasn't flown away yet ;)
https://linustechtips.com/topic/283437-help-with-case-choice/#findComment-3847418
