I have found 280x for 340KM really cheap, that man lives in same town that i do..
And there is some warranty left, but im not sure if GPU is used for Mining or Gaming..
But i can test that GPU so how can i test it to see if it was used for mining or if GPUS is okay?.
https://linustechtips.com/topic/282629-help/
Uh... no real way to KNOW if the card was used for mining. My hint is to take the cooler off, and see if the thermal paste is all eaten. Or ask the guy.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/282629-help/#findComment-3836981
Ask what it was used for and if you could test it. If not, ask to see it working. If he doesn't, he either doesn't want to sell it that bad or the card is messed up. You also need to figure out if the warranty covers cards used by secondhand owners.
CPU: i7 4790k @ 4.6 GHz Motherboard: MSI SLI Plus Krait Edition RAM: 16 GB (2x8) 1866 MHz Kingston Black Fury Series GPU: Gigabyte GTX 970 G1 Gaming Case: NZXT S340 (Black) Storage: Intel 730 Series SSD (240 GB), Seagate Barracuda (1 TB) Display: LG 24MP55 Cooling: Cooler Master Hyper 212 Plus Keyboard: Corsair K95 RGB for gaming (1st Player Fire Dancing for typing) Mouse: Logitech G502 Sound: Corsair Gaming 2100 Vengence 7.1 Headset Operating System: Windows 10
https://linustechtips.com/topic/282629-help/#findComment-3836989
What if i can come to his home to test it, should i just see if card can run..
or you have some ideas? (program to see if everything is fine..)
https://linustechtips.com/topic/282629-help/#findComment-3837004
There is no way to tell a gpu is used for mining before. My advice is make a deal with him that if around a week if the card dies you get your money back but if the warranty is still there i wouldn't worry much. You could always ask him what did he used the card for too
Mainboard:ROG-STRIX-B360-G-GAMING/Cpu:I5 8400 /Gpu: Galax RTX 2070 /Ram: Corsair Vengeance 16 GB DDR4/ Storage:1TB HDD 2 Corsair SSD PSU : Corsair 550W/Cooling: Silverstone Air Cooler/ / Case : Corsair/Keyboard:Razer Chroma TKL/Mouse:Mionix Castor+Steelseries Qck Mass/Headphone:V Moda M100
Quote me if you when me to reply to something.
https://linustechtips.com/topic/282629-help/#findComment-3837005
Yeah just come to his house and run a couple of benchmarks like furmark, unigine,3dmark if the card run those test fine then great.
https://linustechtips.com/topic/282629-help/#findComment-3837013
That'll work. If he would let you to, nhatduy1611's idea is best.
https://linustechtips.com/topic/282629-help/#findComment-3837018
when tests are done, how can i know that GPU is okay? what will it say?
If the gpu run through the test with no crashing or artifact poping up then congrats the gpu is fine. After the benchmark it will show you a score
https://linustechtips.com/topic/282629-help/#findComment-3837069
what is good score?
Depends on the preset. And on the CPU used. And on the memory. And on the Mobo. And the particular cooler used. And the silicon lottery.
Really, just check if nothing is wrong with the card.
https://linustechtips.com/topic/282629-help/#findComment-3837166
what is good score?
Well every system is different so just look up online how other 280x score and compare them. Linus tech tips forum also has threads about benchmarks score . If you need more help just ask the people on the forum i know alot of people here have a 280x in their rig.
Links to ltt threads :  http://linustechtips.com/main/topic/212222-ltt-3dmark-thread/
http://linustechtips.com/main/topic/69448-unigine-valley-benchmark-scores-thread-over-250-submissions/
https://linustechtips.com/topic/282629-help/#findComment-3837175
When i get to his home which program should i use furmark, unigine,3dmark
https://linustechtips.com/topic/282629-help/#findComment-3837200
All of them. I would run 3dmark firestrike first then unigine valley and heaven then finish it off with 30 min of furmark burn in test just to make sure everything work. Running some games is also a good idea if you can.
https://linustechtips.com/topic/282629-help/#findComment-3837244
GPU was used in DarkCoin ..
What should i do?
https://linustechtips.com/topic/282629-help/#findComment-3838085
What should i do?
Is your system listed in your profile the one you going to put the 280x in ? If that's the case then don't bother.
https://linustechtips.com/topic/282629-help/#findComment-3839142
that is my old system..
I have new one but its not finished..
I need 2 more parts
GPU
PSU (Cooler Master B series 500W)
https://linustechtips.com/topic/282629-help/#findComment-3839173
I need 2 more parts
GPU
So? What CPU do you have in that sys? And what do you want to acomplish with it?
https://linustechtips.com/topic/282629-help/#findComment-3839193
I need 2 more parts
GPU
400w is not enough for the 280x. Wait until you get the new 500w psu first.
https://linustechtips.com/topic/282629-help/#findComment-3839200
that is 500W not 400W
that is new PSU
CPU i3
RAM 4 GB 1600 DDR3
https://linustechtips.com/topic/282629-help/#findComment-3839253
that is new PSU
CPU i3
RAM 4 GB 1600 DDR3
? i said never said that that the new psu is a 400w. Read my post carefully again,
https://linustechtips.com/topic/282629-help/#findComment-3839316
you said "400w is not enough for the 280x. Wait until you get the new 500w psu first."
and i said my new PSU is 500W not 400W
You said this" I have new one but its not finished..
I need 2 more parts
GPU
PSU (Cooler Master B series 500W)"
So that mean you don't have a gpu and a psu yet so i said wait until you get the new 500 psu first before getting the gpu.
https://linustechtips.com/topic/282629-help/#findComment-3839369
