AF120's are pretty quiet imo
Everything that's in my PC and on my desk
Intel Core i5 4670K | MSI Z87-G45 Gaming | Corsair Vengeance LP 16GB RAM | MSI GTX 770 Gaming 2GB | Corsair Obsidian 450D | Intel 530 Series 240GB SSD | Toshiba 1TB HDD | Corsair CX750M  | Scythe Mugen 4 PCGH Edition | NZXT Hue RGB Leds | 2x Corsair AF140 Quiet Edition | Corsair AF120 Performance Edition | Nanoxia Frontpanel Extension Red | AOC G2770PQU | CM Storm Quickfire Ultimate MX Brown | Corsair Vengeance M65 FPS | Corsair Vengeance 1500
https://linustechtips.com/topic/281901-quiet-led-fans/#findComment-3827816
Spectre Pros are mediocre at best.
Where are you shopping/located? Budget? Where are you putting the fans?
https://linustechtips.com/topic/281901-quiet-led-fans/#findComment-3827821
The budget isn't really an issue, intake and exhaust location. I'll shop anywhere :D
Intake and exhaust don't give any indication where the fans are being placed.
Please reread and answer the questions. What are your specs?
https://linustechtips.com/topic/281901-quiet-led-fans/#findComment-3827923
Specs are Athlon x4 760k, MSI A78M-E35, GPU GTX 750ti EVGA SC, HDD WD Caviar Blue, RAM 1 x 8GB Vengeance LP DDR3-1600MHz, PSU CX430M, Case CiT Spectre
https://linustechtips.com/topic/281901-quiet-led-fans/#findComment-3827936
https://linustechtips.com/topic/281901-quiet-led-fans/#findComment-3827960
Aerocool Dead Silence LED are very quite with good airflow
At least in my system
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
https://linustechtips.com/topic/281901-quiet-led-fans/#findComment-3828888
Located in the UK but will shop anywhere...
AF120 QE's are alright: http://uk.pcpartpicker.com/part/corsair-case-fan-co9050016wled
If you're a real stickler for quiet but don't need as much airflow, TrueQuiets are very quiet and can be used for exhausts: http://uk.pcpartpicker.com/part/antec-case-fan-truequiet120white
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/281901-quiet-led-fans/#findComment-3847764
