So i saw a while back on the troubleshooting forum someone had some liquid coming from their H100i.
Was that ever determined to be fan oil, damaging, or something i should RMA for?
Because i am having the same issue.
I luckily caught it in time, while doing my weekly dusting and inspection, so it hasn't dripped on anything.
I am currently uploading a video showing it.
It feels like it could be lube for the fans, and it is only on the one fan, that i have replaced through RMA already (another already on the way, for a different reason.) but i want to make sure.
Video link ETA 5 mins.
Thanks.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/281750-h100i-issue/
Classic H100i problems :P
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/281750-h100i-issue/#findComment-3825800
https://linustechtips.com/topic/281750-h100i-issue/#findComment-3825827
The h100i leaks? Wow. I knew it had problems with the stock fans, but one year going and it works totally fine
Well, let me give you advise. For stuff that is sensitive, like all in one liquid coolers, try and buy me from a store near you. If you did, it's a 1 in a 1000 you got a damaged product.
Corsair support is the best I have seen. Take the RMa and closely observer the h100i.
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/281750-h100i-issue/#findComment-3825842
So far it has been nothing but trouble, aside from the cooling performance.
The fans click and squeak, i have already replaced two and have another on the way right now.
The RGB LED is pink when set to red, and corsair link is the most useless thing in the world.
One thing i will give corsair credit for is their amazing RMA process.
All three times i have had to use it, i have had a new fan shipped within hours.
I think if it is actually the loop leaking, and not lube from a fan, i will just return it and get a different cooler.
https://linustechtips.com/topic/281750-h100i-issue/#findComment-3825859
weekly? not really the topic but damn if you check weekly thats a bit nutty in a good way I suppose.
Spend a lot of money on it, you want it to look good.
And damn does it look good...
https://linustechtips.com/topic/281750-h100i-issue/#findComment-3825871
Idk about others but the rgb can be a hassle to fix. First close and open corsair link. Then set all the values of the led to 0. Now set the red to 255 and back to 0. Blue to 255 and back to 0. Green to 255 and back to 0. Now set blue to 1 and green to 1. Finally set red to 255.
Hope this helps!
https://linustechtips.com/topic/281750-h100i-issue/#findComment-3829164
Hope this helps!
Woah.
That actually worked.
Thanks!!!
https://linustechtips.com/topic/281750-h100i-issue/#findComment-3831495
