I am building a gaming pc and need some help choosing a motherboard. So far for my build I have a intel i5 4690k, a gigabyte gtx 970, 16gb of g skills ripjaws x ram, and a samsung 850 evo 250gb. I already have a case and keyboard and monitor. ( WHAT MOTHERBOARD SHOULD I GET?) It's a gaming pc and I will be overclocking slightly and I just want a all around good motherboard my budget is max $300 but preferably under $200. Thks for the suggestions :)
https://linustechtips.com/topic/281560-building/
All motherboards performs essentially the same. Since you are on Intel, you don't need that much power phases.
Main difference would be # of USB ports, SATA, PCIe slots and such.
Are you aiming for a particular color scheme for your build?
CPU: 5820K GPU: Gigabyte G1 970 RAM: 16 GB Crucial Ballistix Mobo: EVGA m-ATX Cooler: Corsair H100i Case: Xigmatek Aquila PSU: NZXT 700W Monitors: 2 x Wasabi Mango (1440p)
Do you play Go/Baduk/Weiqi? I am AGA 4D.
"We do not shop by brand, we shop by what delivers us the best performance, features and quality for the money we're spending" - Linus (Techquickie)
https://linustechtips.com/topic/281560-building/#findComment-3823722
I am not looking for any color scheme
https://linustechtips.com/topic/281560-building/#findComment-3824123
What form factor is your case? Or rather, is there a particular motherboard size you want?
Also, please follow your own thread
https://linustechtips.com/topic/281560-building/#findComment-3824344
Sorry I followed it now and my case is just a regular size case it can fit a regular mobo. (sorry im new to building pc's)
Can you tell me the case's name? I just want to be sure
https://linustechtips.com/topic/281560-building/#findComment-3824696
Im really sorry I dont remeber the case name all I know is that it is a corsair obsidian case but its big so you shouldnt worry about size. And also I did some research and found that this board looked pretty good
ASUS MAXIMUS VII HERO LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard, or the z87 version of it.
https://linustechtips.com/topic/281560-building/#findComment-3824849
I can't see you needing anything more than this to be honest: http://pcpartpicker.com/part/gigabyte-motherboard-gaz97xgaming5
1 Timothy 1:15
https://linustechtips.com/topic/281560-building/#findComment-3825038
