Dear pros, please help me check if my parts are compatible with one another. Here it is:
Fractal Design R5
WD Black Series 4TB
Intel 730 series 240GB
Corsair AX860i
Corsair Dominator Platinum DDR3 32GB
Asus X99 A-LGA 2011 V3
Intel Core i7 5820k
Cooler Master 240M Nepton Series
Gigabyte AMD Radeon R9 290X
https://linustechtips.com/topic/281368-pc-parts-compatibility/
You're going overkill on the Powersupply. Get the AX760/AX760i. you could use the change to go towards a GTX970 instead of the R9 290x
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/281368-pc-parts-compatibility/#findComment-3820119
