Automatic Power-Off
Don't worry, it will probably be the case anyway. My HDD (only storage) will stop frequently if not in use.
It will consume far less power en make a lot less noise!
It will add a little wear to the motor, but it is not that significant. And the advantages are far greater than the little extra wear.
Edit
I know there have been hefty discussions about this topic in the past. The HDD's bearings wear while running, start/stop cycles will wear the motor. One of those two will probably give at some point. But a modern HDD should be able to handle it's for it's life expectancy.
And of course your drive might be the unlucky one which dies a bit quicker due to it, but by the time that happens you really should have a back up of your data. (You probably should always have a back up
