Hi everyone, happy new year to you all,
me and my brother are putting a PC together (which will be for gaming and video editing) and are thinking of using the i7-4970k, as this is our 1st build we are wondering if we will be able to go into the bios a few months down the line and over clock the CPU once we feel a little bit more comfortable doing so? or if this is not such a good idea?
https://linustechtips.com/topic/281316-4790k-and-over-clocking/
If you get a CPU like that, I would be INSULTED if you didn't overclock it at least a bit :P
Just make sure you get a good cooler and you can really push a lot more out of those. Don't be nervous, there are many safety feastures that prevent you burning it out. Just follow a guide somewhere :D
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3819487
Yeah sure its not a problem, especialy with 4790k i have it myself it was a treat OCing it, 4.4 is base overlock with a guide ocing it to 4.6 with good cooling is easy as hell 2/10 i would say the level how hard it is. With proper AIO, or waterloop i am sure getting it to 4.8 is also very posible with a little bit of playing around with voltage etc :)
Go for it its a magnificent CPU for gaming also.
But if you want to have temps rly rly down, like 45ish get 240 rad AIO :)
i have air cooler CM GTS V8 which is kinda bad for that money i just love the looks and i got 4.6GHZ stable out of it with temps maxed at load at 82 degrees which is acceptable :)
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3819488
Thank you for the advice! Having watched a couple of guides I have a few questions, does anyone have/know of a good guide I could read as I'm getting a bit confused about a few things,
such as how OC'ing the CPU will affect other components.. I don't intend on OC'ing anything else i.e ram (gpu will come factory oc'd) but will the ammount I oc my cpu affect how it interacts with the ram, gpu etc? Or the speed of the ram I can use?
I don't know if I'm totally lost here sorry.
Thank you in advanced for reading these ramblings... We'll get there in the end.
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3821607
Nope ocing your cpu doesnt affect your other components, its only affects the effectivity of handling for example the extra ram, so if you oc a CPU and add extra ram that ram is to be faster used making the for example Rendering procces faster.
The only problem is the more you OC you CPU the lifespan of it can decrease but ocing 4790k its ok because the K stands it was made for OCing just remember the magical frequency when you are dealing with shorter lifespan is around 4.8 so i would recomend ocing max to 4.8, 4.7 just to be sure :) It will run as long as its cool and with propper voltage just fine as would stock one.
Now to RAM dont oc that, its not realy needed, you can check linuses videos just on that, ocing ram doesnt increase the performance by much, if by any %. +1000MHZ
may increase the speed of some tasks by some 1% thats nothing so dont do it its too time consuming to get everything right so it will run crashing. If you got it by accident OCed and everything is stable then sir good for you leave it :P
And to the GPU now, even when it comes OC from the factory there is nothing said about not OCing it a bit more :P
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3821830
Thank you for the advice bughtoo that clears a few things up! I think Ill still be watching a few of linus' guides before we take the plunge though!
We'll be using asus bios (maximus vII ranger) our full parts list can be seen in this thread:
http://linustechtips.com/main/topic/281322-brother-build/
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3827872
The only time OCing your CPU affects RAM is when adjusting the base clock (bclk) of the system. RAM runs off the bus speed there; therefore raising the bclk will raise the RAM speed. You would not be aiming to adjust bclk however; you'd be aiming to adjust the core multiplier of your CPU. If you do not wish to use the BIOS to overclock, another utility is Intel XTU which is free.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3828887
Hi i don't know if it fits in here but i'm having trouble with my 4790k. I can run it at 4.6GHz with 1.180v with manual voltage (be quiet! Dark Rock 3 73°C) but when i'm setting it to Adaptive voltage it pulls between 1.213 and 1.280 volts and then it starts to get to 90°C but i don't know why it's doing it.
hope some one can help me out :-)
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3828984
what adaptive voltage did you set? what offset did yo uset? everything is on default?
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3829151
set the offset max to 0.100 :) thats why its going of the hood up :)
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3829488
ohh thank you so much :)
sorry
set it to 0.05 :D
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3829502
my bad 0.1 wouldnt change anything set it to 0.05 that should alright if its still to much for the heat, set it even lover :)
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3829504
Oh Rly? thats weird and did yo uset it in bios? or in windows in some tune program?
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3829762
oh well i am lookign at it right now i have the same thing when i set voltage to 1.2 and offset to 0.05 during aida64 performance test i got 1.3volts i guess its the motherboard preinstalled capabilities to increase it so it is more stable.
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3829992
but trust me, the bigger OC the bigger voltage you need, the more voltage you need the more heat it outputs, the more heat it outputs the better cooler you need :)
So OC only in the range of  your cooling posibilities :)
https://linustechtips.com/topic/281316-4790k-and-over-clocking/#findComment-3830615
