would i be able to find a closed loop liquid cooler for the gtx 780 ?
I wont think so.
But you can build cheap custom loop.
https://linustechtips.com/topic/28099-liquid-cooling-gpu/#findComment-357302
 how much would this cooler cost?
Well the bracket is about 30$ they said + what ever an NZXT Kraken costs ^^
Custom really depends on what you want to build and so on. But will give you better performance for sure.
Linus is mentioning it in one of his Computex Videos, go search for it ^^
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/28099-liquid-cooling-gpu/#findComment-357330
I don't think it has to be a kraken but don't qoute me on that.
https://linustechtips.com/topic/28099-liquid-cooling-gpu/#findComment-357421
Arctic Cooling has a closed loop system as well, it looks like it is an Asetek cooler for which they made the mounting hardware.
http://www.arctic.ac/en/p/cooling/vga/569/accelero-hybrid.html?c=2182
i5 2500k @ 4.4GHz EK watercooled || SLI GTX680 EK watercooled || MSI Z77A-GD65 || 16GB Corsair Vengeance LP || Crusial M4 128GB SSD || 1TB WD Green || Silverstone TJ07 || Corsair AX750 || Dell Ultrasharp U2713HM || Beyerdynamic DT 990 250Ω || Asus Xonar Essence STX || Logitech Z906 || QPad Mk80 || SteelSeries Sensei || 3DConnexion SpaceNavigator
https://linustechtips.com/topic/28099-liquid-cooling-gpu/#findComment-359633
  • 1 month later...
