I think typically you don't want to go over 80 degrees. I think CPUs generally start throttling themselves over 90 or something like that.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/28048-acceptable-temps-for-8350/#findComment-356650
Heya,
What temps are you getting on your CPU?
I read that say around 62c - 65c.
from Over clockers forum
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/28048-acceptable-temps-for-8350/#findComment-356653
That is intel temps, FX-8350 turns of automatically at 75ºc
https://linustechtips.com/topic/28048-acceptable-temps-for-8350/#findComment-356659
That low? I thought the FX-8350 generated a lot of heat, especially when overclocked?
Just goes to show that it's been too long since I've built an AMD system. I see Steamroller in my future.
https://linustechtips.com/topic/28048-acceptable-temps-for-8350/#findComment-356689
Still it generates lots of heat,but you just must have great cooler.
Thats why i have custom loop.
I have FX-8350@5.1Ghz and temps are max 45ºc
https://linustechtips.com/topic/28048-acceptable-temps-for-8350/#findComment-356719
I can't find a official statement but i have read that AMD wants you to run that CPU at 62 °C max, but the throttling starts at 68°C, and the CPU shuts down at 75 degrees, so for an overclocked 8350 you need high end air cooler like an NH-D14, or a Silver Arrow, or you can get a h100 Kraken x60 for that, 4.5 is doable on high end air and a closed loop, but if you want that bleeding edge 5 ghz, custom loop is a must...
System
CPU: i7 4770kMotherboard: Asus Maximus VI HeroRAM: HyperX KHX318C9SRK4/32 - 32GB DDR3-1866 CL9 / GPU: Gainward Geforce GTX 670 Phantom Case: Cooler Master HAF XBStorage: 1 TB WD BluePSU: Cooler Master V-650sDisplay(s): Dell U2312HM, LG194WT, LG E1941
Cooling: Noctua NH-D15Keyboard: Logitech G710+Mouse: Logitech G502 Proteus SpectrumSound: Focusrite 2i4 - USB DAC / OS: Windows 7 (still holding on XD)
https://linustechtips.com/topic/28048-acceptable-temps-for-8350/#findComment-357126
Well I've been hearing about 62°C max for the chip and 72°C for the socket.
I get around 50-55°C on my chip with prime95 running with 1.440 volts and 4.6Ghz on my 8350, and that's with IC Diamond and fans turned to max on my silver arrow extreme (stock fans) and my ambient room temp is around 20°C I think.
Edit: Well I've Changed some things around now and my temps on the chip are about 46, same conditions.
System specs
  • Graphics card: Asus GTX 980 Ti (Temp target: 60c, fan speed: slow as hell)
  • CPU: Intel 6700k @ 4.2Ghz
  • CPU Heatsink: ThermalRight Silver Arrow Extreme
  • Motherboard: Asus Maximus Viii Gene
  • Ram: 8GB of DDR4 @ 3000Mhz
  • Headphone source: O2 + Odac
  • Mic input: Creative X-Fi Titanium HD
  • Case: Fractal Design Arc midi R2
  • Boot Drive: Samsung 840 Pro 128GB
  • Storage: Seagate SSHD 2TB
  • PSU: Be quiet! Dark Power Pro 550w
Peripherals
  • Monitor: Asus ROG Swift PG278Q
  • Mouse: Razer DeathAdder Chroma (16.5 inch/360)
  • Mouse surface: Mionix Sargas 900
  • Tablet: Wacom Intuos Pen
  • Keyboard: Filco Majestouch Ninja, MX Brown, Ten Keyless
  • Headphones: AKG K7xx
  • IEMs: BrainWavs S1
https://linustechtips.com/topic/28048-acceptable-temps-for-8350/#findComment-358395
