no post help
By
titan_007
in Troubleshooting
in Troubleshooting
Solved by unidentical,
Check to make sure the memory is seated properly, and make sure there isn't anything caught between the motherboard and the tray. almost sounds like it's shorting somewhere (which I have seen with having an extra standoff or something wedged in behind.
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
