Some overclockers overvolt their CPU with raising the voltage offset (e.g.: +0.100V) and others simply type in a higher core voltage (e.g.: 1.100V). What ist the difference?
most CPUs have their stock voltage around 1 volts. normal OCers use to only higher with max 0.3 to 0.5 to be safe. It also depends on temps.
it is not the volts which kills your CPU. it is the temps.
Imagine your CPU having small wires inside it like a light bulb. With overheating the wire break till the end. That is why good cooling is important
You can have your CPU at 1.5 volt and have 70 max temps and it is fine.
many ppl missunderstand that it is not the volts which kills you CPU, it is the temperature. But Higher volt = higher temperature..
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
