Help with corsair utility engine (M65 mouse)
Solved by manwithmannynames,
Not sure quite how to fix it, but I will try to help as I would like to learn how to do all the macro stuff as I got the same mouse except non-rgb.
Try setting your playback options to the play/stop setting then try the macro.
AAHHHH YIIIIISSS I solved it ! What you need to do is click on pointed-down-arrow of the hotkey in question and go to 'remap button/key' and look for the key you want !
Featured Topics
2
coolbean28 ·
Posted in Graphics Cards7 -
awsomename999 ·
Posted in Troubleshooting3 -
RoyTheGeek ·
Posted in Phones and Tablets1 -
NexDeformedpoto ·
Posted in Networking2 -
4
7
2
Soapy1234 ·
Posted in CPUs, Motherboards, and Memory6
