Help With K70 RGB
Partha112
The D Keycap on my Corsair Gaming K70 RGB fell off, but I can't figure out how to contact Corsair to get a new one. Has anyone had a similar situation? How did you get your new keycap?
It should pop right back on really easily.. It's almost impossible to break the keys.
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
I tried that, it seems like something on the bottom broke. Might have been defective.
Can you get a picture of the inside of your keycap? Sounds like something is broken.
there are some websites where the sell replacement keycaps(WASDKeyboards) (and ebay) try looking there first
(and if u are using the textured keycaps, I would just put the normal back on or the other way around)
and how did it "fall off" if its sideways it might be the + slot at the bottom, and might be fixable with superglue
[insert stuffs here]
Unfortunately, replacing them isn't an option. I'll try to get a pic.
