Shutting down problem
By
Mr.Norton
in Troubleshooting
in Troubleshooting
Solved by tmlhalo,
Maybe something with the front panel header on the motherboard or the physical power button on the case? Try removing everything plugged into the front panel header on the motherboard and flip the psu back on to see if it stays off.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning1 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
