"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/279364-need-manga-help/#findComment-3792026
How's the G5 build coming ;)
season appropriate, going nowhere due to xmas xD
https://linustechtips.com/topic/279364-need-manga-help/#findComment-3792050
I'm looking for an app that has mostly all manga. I tried Manga Rock but it doesn't have Nisekoi and I really want to read it. I'm open to all suggestions.
Here comes a resident manga guru to the rescue :D
I usually read it on my laptop, but i'm using Mobi Manga for mobile, since it's a compilation of multiple sites (like MangaFox, MangaReader...) :D
Don't use MangaRock! It used 500~ Mb of data (out of my 2Gb monthly), in 10days, and that was in background... :D
https://linustechtips.com/topic/279364-need-manga-help/#findComment-3792060
I'll check it out :)
https://linustechtips.com/topic/279364-need-manga-help/#findComment-3792098
just go to kissmanga and you should be fine unless you want to download it
if you wanna download it try nyaa.se or animebytes
manga rock is epic on ios but kinda shit on android as you can only download 1 manga at a time on android and inf on iso for free
AnimeFAN
https://linustechtips.com/topic/279364-need-manga-help/#findComment-3823251
