Interface
Solved by JaSoN_XzIoN,
I am trying to build a new computer. The motherboard and GPU both have HDMI built-in. Is there any reason to use one HDMI port over the other?
The motherboard port should be disabled as soon as you pop in the GPU, so use the GPU's port. They work independently from each other, so the motherboard connector won't use your GPU's power, it will use the cpu's built in gpu
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
