My front panel USB ports don't recognize my wireless mouse
Gidoguy
I finished my PC build recently, everything worked fine, the computer runs smoothly. However, when I come to plug my USB wireless mouse into my front panel USB ports, it doesn't show up. I tried putting it into my mobo USB ports, and it works fine. (I can't use the rear ones because my mouse keeps loosing range and lagging due to where everything is situated), I plugged in my keyboard and external hard drive, both of these show up and work fine. It's not my mouse, it's not the front panel USB ports, what is it?
Note: I've done all the driver stuff, uninstall and reinstall etc, I'm no idiot
My mouse
http://www.microsoft.com/hardware/en-gb/p/wireless-mobile-mouse-1000
My case
http://www.amazon.co.uk/CiT-Vantage-Gaming-Audio-Reader/dp/B0071KZNUY
Δ Ambassador for the Illuminati Δ
Δ "Illuminati confirmed" - Nobody  Δ
Are the front panel ports plugged into the mobo?
yes
did you try using anything else with the front ports, it might be a frayed wire or bad mobo connector for USB
[insert stuffs here]
My mouse
My case
I have had this issue sometimes with USB 3.0 ports on the front IO, but never USB 2.0 ports, i might try hooking the front USB inside your case to a different USB header and see if that fixes the problem. I would also check the little circuit board where all the connections plug in up top to make sure nothing got yanked on.
Main Rig: | CPU: Intel Core i9-7900x | GPU: Nvidia RTX 2080 Founders | Mobo: Asus ROG Strix X299-E Gaming | RAM: 32GB Corsair Vengeance LPX DDR4 3000 MHz | SSD: Samsung 980 Pro w/Heatsink 1TB & Samsung 960 Pro 1TB | Sound: Parasound ZDAC & Burson Soloist Amp | PSU: Corsair RM850 | Fans: 2x Noctua NF-F12 | Case: Caselabs MAGNUM SMA8 | Headphones: Sennheiser HD 800 | Keyboard: WASD V3 | Mouse: Logitech G502 Lightspeed | Mousepad: Logitech G PowerPlay | CPU Cooler: bequiet! Dark Rock Pro 3 | Primary Monitor: Acer Predator XB272 | Extra Monitors: Samsung Syncmaster PX2370 |
