i currently used nuclear tec night star UV coolant blue for my loop.. however its colour too light.. so i want make it darker..i have cyan ink from HP printer.how about i pour that ink into my coolant.. will it damage my hardware (radiator, pump and water block)?..; i googled that ink made up from, but i got no answer? any professional over here? help me please!!!
https://linustechtips.com/topic/278192-coolant-dye-need-help-over-here/
any explanation for this?
Will you please just use the apropriate equipment for the job? I wouldn't use a hacksaw to cut a house brick in half... I'd use a circular saw with a masonry cutting disc...
Buy some dye for liquid cooling, preferably some that is UV reactive.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
