Ok, so I have this rig for about a year now, and on the summer time, it was giving me very high temps, so I decided to modify the fans asap.
Now, christmas time, I got some money, I started thinking about it, and so I would like you guys' opinions on the matter.
The question I ask here is, will this be enough or should I go a different route, choose different fans, etc.
feel free to comment on what you think should be said
The rig:
   -AMD fx-8350 4.0ghz
   -msi r9 270x
   -8gb kingston xmp beast
   -120gb samsung 840evo ssd
   -1tb wd blue
   -corsair vs650     650w
   -asus M5A99X
   -corsair Graphite 230T
   -cooler master hyper 212 evo
picture ( sample image from g.images just to explain the deal):
https://linustechtips.com/topic/277782-airflow-help-needed/
I would put the BeQuiet fan at the bottom for intake. The rest looks fine.
https://linustechtips.com/topic/277782-airflow-help-needed/#findComment-3768145
Um.. Do a double intake, rear as intake (get a dust filter of some sort) and up the top a double outtake. This gives you positive air pressure inside the case which means less dust which is always a great think.
Ty both, about the cpu cooler, do you think I should go with the sp120 or the bequiet?
https://linustechtips.com/topic/277782-airflow-help-needed/#findComment-3768243
BeQuiet fans are better.
https://linustechtips.com/topic/277782-airflow-help-needed/#findComment-3769273
