mic problems! help
Go to solution Solved by Hansell,
thanks dude this helped lodes!"
you are welcome mate :)
so i got my corsair vengeance 1400 and the mic on it is abit strange i plug it in and i get realtek ask if i want line in or mic in, i have chosen both then i go to recording devices look at the green volume levels and nothing happens when i talk!!! help! please!!!!
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/277517-mic-problems-help/
well, I do have a vengeance 1400 also, let me see, have you try this,
at windows seach panel, manage audio devices ->recording ->choose your mic -> properties -> levels ->slide the slider to the maxxxx
on windows 7 tho
https://linustechtips.com/topic/277517-mic-problems-help/#findComment-3765402
on windows 7 tho
im trying to work how to do that in windows 8 hang on mate.
}else{
https://linustechtips.com/topic/277517-mic-problems-help/#findComment-3765419
on windows 7 tho
}else{
https://linustechtips.com/topic/277517-mic-problems-help/#findComment-3765476
