First Build! Need Help Picking Components?
I've been messing around with my components for a few weeks now, I thought I'd try and get some help from some more experienced people for the best possible build for my budget! I'm in the UK so I'm on £!
My complete budget is £800 but I CAN'T go any more as that's all I can spare for the build!
Cpu: Intel Core i5 i5-4690K
Mobo: Asus P8Z77-V LX
Ram: HyperX FURY Series 8GB (2x 4GB) DDR3 1866MHz
Storage: Hitachi Deskstar/ UltraStar 3.5"1tb 32mb Sata 7200rpm
GPU: Asus Nvidia GeForce GTX 760
PSU: Cooler Master V Semi-Modular Series V550
Case: NZXT Phantom 410
Optical drive: Samsung 24x Retail SATA DVD Writer
Monitor: Asus VS239HV 23 inch
Keyboard/Mouse: Cooler Master CM Storm Devastator
TOTAL: £780.80
Any opinions or help would be great
This build is built for gaming so I tried to focus in the GPU
I want every thing on a single site (I used Amazon) because I don't want to mess around to much.
https://linustechtips.com/topic/277119-first-build-need-help-picking-components/
Its a pretty decent build. However, the motherboard you have is not compatible with the CPU. The P8Z77-V LX is a socket 1155, while the CPU is socket 1150. So you could go with an ASUS Z97-A. You could go with 1600mhz ram to give you a bit more towards the GPU, or to go towards an SSD. But I'd say you're pretty well set.
Oops... Good thing you said about the motherboard, and I'll sea what I can get by lowering the ram Thx
