Display Adapter Problem
Go to solution Solved by W-L,
I have one laptop with one vga connector with two other monitors i want to extend to. What is the best way to extend to these monitors. The laptop is a y410p and the monitors are 720p with vga inputs only (no they are not for gaming). What do i need to run these in dual monitor mode?
You can't extend two monitors via a single vga output unfortunately, you will either need to get a USB to VGA adapter to have both of those monitors or since you have an HDMi output on your laptop a digital to analog converter to adapt hdmi to VGA.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812400393&cm_re=usb_to_vga-_-12-400-393-_-Product
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16812400535&cm_re=usb_to_vga-_-12-400-535-_-Product
https://linustechtips.com/topic/276510-display-adapter-problem/
or
https://linustechtips.com/topic/276510-display-adapter-problem/#findComment-3753982
or
https://linustechtips.com/topic/276510-display-adapter-problem/#findComment-3754199
