fan help
Go to solution Solved by AverageHardware,
According to the Corsair website for the 760T, here are the specs my friend:
Fan Mount Locations
Front: (x2) 120/140mm
Top: (x3) 120mm or (x2) 140mm
Rear: (x1) 120/140mm
Bottom: (x1) 120mm
Fans Included
Front: (x2) 140mm
Rear: (x1) 140mm
Hello everyone!
I am building a new computer, my first! I did already make a post asking questions but I have one more. I am building linus 4k build, exactly the same except I am getting duel 980 overclocked graphics cards. but in his build he changed all the fans. I am using the Corsair Obsidian Series 760T case. Linus replaced all three fans with the Bitfenix Spectre Pro LED Fans, are all the fans in the case the same size(140mm)? I already bought all the parts and three 140mm Bitfenix Spectre Pro LED Fans but if they are not the same I will return them. Thank you :-)
Hope I was able to help! :D
I'm not a tech expert, but I do know a lot about Computers and Networking that I taught myself.
If you have any questions for me, feel free to PM me or reply to my post :)
https://linustechtips.com/topic/276408-fan-help/
Fan Mount Locations
Bottom: (x1) 120mm
Fans Included
Front: (x2) 140mm
Rear: (x1) 140mm
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
https://linustechtips.com/topic/276408-fan-help/#findComment-3752828
Fan Mount Locations
Bottom: (x1) 120mm
Fans Included
Front: (x2) 140mm
Rear: (x1) 140mm
Thank you averagehardwarw, I think I got the right ones! :-)
https://linustechtips.com/topic/276408-fan-help/#findComment-3760816
