Hey,
Until recently, my 780 SC from EVGA ran fine. I mainly play BF4, and at 1080p, ultra settings, everything cranked up I could always get 60+FPS which is enough.
A few weeks ago I cleaned my PC. Afterwards, my frames dropped to around 30. Yesterday I checked and my 6pin wasn't plugged in all the way, so I fixed that. I had a couple of rounds without any problems, but now I'm having the same FPS issue again. I've attached a GPU-Z sensor log. Please help me, I have no idea what's causing this and I'm fairly certain it's my GPU.
H97N-WiFi, 4690, 8GB DDR3 1600MHz, and Windows and the game is running from a 250GB 840 Evo with the magic "performance fix" installed.
Cheers,
Haber
GPU-Z Sensor Log.txt
https://linustechtips.com/topic/276235-780-going-weird/
Could have caused a short from running it with the 6 pin not plugged in all the way for extended periods of time. Do you have another card to test out with, or a friend's card you can borrow to see if it is the GPU itself?
https://linustechtips.com/topic/276235-780-going-weird/#findComment-3751115
