Hi,
I've had a chromecast for a while, haven't used it much. However, I want to start using it. I have a Plex media web server thing set up on my PC upstairs, and the chromecast in the 50" TV downstairs. I want to stream my films from the Plex server to the chromecast so I can watch it on the TV. How can I do this? Whenever I play a film through Plex, it plays in the browser right? How can I stream it to the chromecast? Also, how can I stop/pause the film while sitting downstairs without having to run upstairs to my PC to pause it?
Thanks
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/276169-chromecast-help/
You'll need Chrome's Chromecast plugin to stream to the Chromecast. Either that or download and use the Plex app on a smartphone.
If you want to be able to pause/play from your sofa rather than run to your computer, you'll need the smartphone app.
https://linustechtips.com/topic/276169-chromecast-help/#findComment-3749637
Ah, there's an app? I'll check it out, thanks
https://linustechtips.com/topic/276169-chromecast-help/#findComment-3749662
