Modding Idea
Go to solution Solved by MourningSouls,
Pretty sure I saw a picture of another dude who did this yesterday.
EDIT: Here: http://linustechtips.com/main/topic/274667-christmas-gaming-mini-itx-pc-isnt-supposed-to-work-but-it-does-d/
Hey guys! So I'd just like to share a quick mod idea I might try.
I have the Bitfenix Prodigy case and I was thinking of how I could possibly get a GPU with a Kraken G10 from NZXT to fit in there. It obviously had plenty of radiator possibilities, but the Kraken makes the GPU footprint equivalent to if it were to have a three slot cooler. Now since the Prodigy only has 2 expansion slots this obviously won't work right?
Well hold on there! Here's where my super complicated ultra modding idea/plan thing (it's not hard) comes in! The bracket itself doesn't need a slot, just the room for one. So what if one were to just
a. Cut a hole in the side panel (The not so elegant solution) or
b. make a custom side panel or window with a bulge to allow for the extra space needed!
Basically it would slightly change the look of the case, and one could try to mirror the effect if they saw it necessary.
So what are your thought's on this? I for one am probably gonna go for it! I love a good challenge!
Feel free to ask questions and suggest ideas!
The year is 20XX. Everyone plays Fox at TAS levels of perfection. Because of this, the winner of a match depends solely on port priority. The RPS metagame has evolved to ridiculous levels due to it being the only remaining factor to decide matches.
Only Abate, Axe, and Wobbles can save us.
https://linustechtips.com/topic/275620-modding-idea/
Do it and post pictures.
It would be a while. I still need 200 USD to get the machine up and running. Just an idea I had but I'll defiantly share when I can do it.
https://linustechtips.com/topic/275620-modding-idea/#findComment-3742661
Okay, sounds good. I understand a lack of funds.
https://linustechtips.com/topic/275620-modding-idea/#findComment-3742667
"Now since the Prodigy only has 2 explosion slots this obviously won't work right?"
Well that's some volatile case you have there ... B)
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/275620-modding-idea/#findComment-3742698
lol. oops. You know what I meant!
Also I couldn't see the text till I saw it in the quote because of dark theme.
https://linustechtips.com/topic/275620-modding-idea/#findComment-3743018
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/275620-modding-idea/#findComment-3744288
Thanks for showing me this!
https://linustechtips.com/topic/275620-modding-idea/#findComment-3745836
