Hi everyone ! First time here on this Amazing forum. When i can start ?
I want to upgrade my Desktop PC and right now my Hardwares are :
Mobo: UD5 rev2 x58a
GPU: EVGA 780 classified
CPU: i7 930
RAM : 6GB
Power Supply: TX750w bronze
I want to change only my mobo, cpu and RAM and put a SSD.
I'm a Gamer and a photographer / videomaker and i need to do this task in one Rig.
Can you help me ? :D
https://linustechtips.com/topic/275546-help-for-gaming-rendering-rig/
What is your budget?
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
it isnt better a 2011 Socket ? i think it's better for a future upgrade. 'Cause i knoe, and guessing  :D , that with the LGA2011 i can upgrade with a  2011-3. Am i right?
2011 and 2011-3 aren't compatible as I recall. (because Intel said so)
Do not  as I  do, and  not  as I say. Instead do as you may..
HSS Revenir: CPU=i7 5960x @4.5GHz Heatsink=Corsair H100i MOBO=ROG Rampage 5 RAM=Kingston HyperX Predator 16GB @3000MHz SSD=Corsair Neutron GTX 480GB GPU=R9 295x2 PSU=Corsair AX1500i OS=Windows 7 Ultimate
So, what RAM you suggest me?
Really I can't like tell you one specific one depends on the prices, but good brands are Crucial (Ripjaws series is good), Kingston, G.Skill (Ballistix) and Corsair (vengeance don't go the the expensive dominator platinum).
In the Netherlands 2 x 4 Gb of Ripjaws X series CL9 1866 Mhz is around 73 euro's.
