Soo im just wondering why the Downloaded Spotify client and the webplayer client have diffrent max volumes.
the volume mixer is Max but the volume that changes (the grayed out bar) stops around 75%
But the Webplayer (Chrome/Firefox) Uses the full 100% of the volume.
The downloaded client goes to about 75% volume
Webplayer client goes to 100%
(Green bar shows the current volume related to the Max volume set, and the Gray Volume shows the Max volume it can be at 100%)
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/275161-spotify-volume/
@ThyFeared Yes mine goes max like yours but in the Audio Mixer on my system the Volume never actualy goes 100% even tho is it set at 100% but on the web client it does
The audio is louder at 100% on a web browser
Mine goes to max so must be a issue with yours
Are you sure that there's no setting in the options somewhere that sets a max volume?
https://linustechtips.com/topic/275161-spotify-volume/#findComment-3737348
