Hello everyone
First custom gaming PC, just want your expert advice on it...
http://uk.pcpartpicker.com/p/DztCqs
CPU - AMD FX-6300 3.5GHz 6-Core Processor - £74.00
Motherboard - MSI 970A-G43 ATX AM3+ Motherboard - £45.95
Memory - G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory - £57.83
Storage - Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive - £39.99
Video Card - Asus Radeon R9 290 4GB DirectCU II Video Card - £215.00
Power Supply - Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply - £44.99
Case - BitFenix Neos Black/Red ATX Mid Tower Case - £29.75
Operating System - Microsoft Windows 8.1 (OEM) (64-bit) - £71.60
Please tell me what you think. Should I hit the buy button?
(By the way I don't care about SSDs)
Thanks
https://linustechtips.com/topic/275140-component-choice-help/
I just don't really find the price to benefit ratio is very good.
What would you recomend?
What's your budget, location, computer use, and do you need windows or peripherals?
The FX 6300 can handle probably an r9 270 without bottlenecking it.
https://linustechtips.com/topic/275140-component-choice-help/#findComment-3736112
