H220 Fan Controller
Go to solution Solved by Tony N,
I wouldn't, from what i have read H220+Voltage control is a big No No. Just hook it up to the splitter or Mobo. I use the splitter because it gets the pump the voltage it needs and that's what swiftech recommends.
And Noctua said there is no black versions of fans coming out, those were just prototypes.
I everyone i just recently bought an H220 and should be arriving Friday and would like to know if anyone knows if the pump can be controlled thru a fan controller
The fan controller i have is Scythe Kaze Master Pro 5.25 Fan Controller
On a side note i believe in this video was a preview of black NF-12 does anyone know if they would say be coming out in say at least 6 months don't wanna buy brown version in build more black white but know how good NF-12s are
https://linustechtips.com/topic/27501-h220-fan-controller/
https://linustechtips.com/topic/27501-h220-fan-controller/#findComment-349777
Thanks for the help thats good to know i would've hooked it up to the fan controller and might of damaged the h220 will just plug it into the splitter/CPU header
and ahh those were just prototypes  :( well guess i'll get the classic browns lol
https://linustechtips.com/topic/27501-h220-fan-controller/#findComment-349825
