Need help finding Gfx driver
Go to solution Solved by dragoon20005,
tried it gave me an error saying failed to detect compatible hardware since i have literally no driver at all installed on here
use the update driver method in the device manager and select the INF file in the downloaded driver folder
http://us.gateway.com/gw/en/US/content/drivers-downloads
use the above and select your notebook model
you can use the Win 7 32Bit drivers
My acer laptop is using the Vista 64 bit driver on Win 8.1... :P
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
i would appreciate the help searching for them
what brand and model of laptop you using?
just do a search on the laptop manufacturer website
eg: HP, Acer, Lenovo, etc
there is an intel and an ati
your GPU is AMD so pick ATi
ATi/AMD are the same company
Intel is for your notebook model which only use Intel HD graphics
i know they're the same thank you i'll do the other install tomorrow thank you for helping have a good night
