Sorry for my spelling
what kind of surface are you looking for?
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/274530-mouse-mat-help/#findComment-3727768
How long and how wide? There are mousemats that can take up an entire desk space.
A great mouse mat is the SteelSeries Qck+ (450mm by 400mm)
Laptop: Intel Core i5-4200H, 8GB RAM, 750GB HDD, GeForce 840M
Desktop: Intel Core i3-6100, 8GB RAM, 750GB HDD, GeForce GTX 750 Ti
https://linustechtips.com/topic/274530-mouse-mat-help/#findComment-3730714
Hey!
Me myself use multiple mouse pads. I have a smaller ASUS one that I got for free which I actually really like.
On top of that I have a QCK+ for gaming. Although I'd recommend a thicker mat for example the QCK Heavy
which is like the QCK+ material wise but thicker which feels really good.
My recommendation is to go to your local store and test them out so see which one you like the most.
Good luck!
https://linustechtips.com/topic/274530-mouse-mat-help/#findComment-3734306
