I have a budget between 1000$ and 1150$  to buy the config (I have already bought the case and its a NZXT Phantm PHAN-001WT White Steel, i also have two monitor, a mouce and a keyboards and i dont plan on overclocking it.
I want to play game like arma 3, BF4 and more...I would also do school works on it and go on facebook, youtube..
I live in Canada Qc.
https://linustechtips.com/topic/273824-first-build/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.98 @ OutletPC)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler  ($74.99 @ Amazon)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($138.99 @ SuperBiiz)
Memory: Kingston HyperX 8GB (2 x 4GB) DDR3-1600 Memory  ($87.99 @ SuperBiiz)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($98.99 @ Amazon)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card  ($278.99 @ SuperBiiz)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($108.99 @ SuperBiiz)
Total: $1163.90
Generated by PCPartPicker 2014-12-20 16:01 EST-0500
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/273824-first-build/#findComment-3718925
I am a owner of a phantom case, I can tell you now. Do not use that case with a air cooler heat sink the air flow isn't that great for intake air for the cpu. If your going to spend 75.00 on the noctua cooler you might as well spend the extra 15 and do a h100i amazon has them for 89.99. Also be sure to upgrade the stock fans as they do not move air very good. For a budget I would use Sickles by cooler master they move up to 70 cfm
https://linustechtips.com/topic/273824-first-build/#findComment-3719163
If you plan on upgrading in the future I would do what jolly Roger said up top no need, just depends on what YOU want. If I would change anything that he suggested it would be the cpu cooler instead of the noctua I would do to a corsair h100i because of that case. You'll also be able to do a better overclock with it. I would go with a 750 watt power supply 850 is over kill for that set up you can still run 2 video cards on a 750 if you wanted. Also instead of radeon video card I would do a gtx 760 by evga. I had one and all I play most of the time is bf4 I just didn't max out my settings. I was on a budget like you i made the mistake of buying a hyper 212 heat sink and basically wasted that money. Yes battlefield is optimized for amd video cards but no one can really tell a difference. Radeon cards also run hotter than nvidia. Your goal with that case my friend is temps. I will try to post parts later just message me I'll help you out
https://linustechtips.com/topic/273824-first-build/#findComment-3719319
My setup,
Case is the Black phantom 410
power supply is EVGA 750 80 plus gold mod
Asus Z97 Pro AC with wifi
i5 4690K over clocked to 4.4 at 1.2volts
video card is EVGA gtx 780
h100i cpu cooler
Samsung 840 250GB SSD
Wd black 1 TV Had
8GB Crucial Ballistix Sport Blue 1866
3 coolermaster sickle fans 2 for front intake and one as back exhaust
I also have my power supply as a exhaust.
My h100i has to fans on the top of my case for exhaust
My cpu at gaming is 53 °c
MY Gpu is at 65°c
https://linustechtips.com/topic/273824-first-build/#findComment-3719503
So i finished up whit that:
**CPU** | [intel Core i5-4690K 3.5GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80646i54690k) | $219.98 @ OutletPC
**CPU Cooler** | [Corsair H100i 77.0 CFM Liquid CPU Cooler](http://pcpartpicker.com/part/corsair-cpu-cooler-h100i) | $89.98 @ OutletPC
**Motherboard** | [MSI Z97-GAMING 5 ATX LGA1150 Motherboard](http://pcpartpicker.com/part/msi-motherboard-z97gaming5) | $138.99 @ SuperBiiz
**Memory** | [Kingston Fury Red Series 8GB (2 x 4GB) DDR3-1600 Memory](http://pcpartpicker.com/part/kingston-memory-hx316c10frk28) | $78.99 @ Amazon
**Storage** | [Crucial MX100 256GB 2.5" Solid State Drive](http://pcpartpicker.com/part/crucial-internal-hard-drive-ct256mx100ssd1) | $98.99 @ Amazon
**Storage** | [Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex) | $39.99 @ Best Buy
**Video Card** | [EVGA GeForce GTX 760 4GB Dual FTW ACX Video Card](http://pcpartpicker.com/part/evga-video-card-04gp43768kr) | $283.99 @ SuperBiiz
**Power Supply** | [EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply](http://pcpartpicker.com/part/evga-power-supply-220g20750xr) | $89.99 @ NCIX US
**Optical Drive** | [Asus DRW-24F1ST DVD/CD Writer](http://pcpartpicker.com/part/asus-optical-drive-drw24f1st) | $14.98 @ OutletPC
**Case Fan** | [Corsair Air Series AF120 Red 52.2 CFM 120mm  Fan](http://pcpartpicker.com/part/corsair-case-fan-co9050015rled) | $14.98 @ OutletPC
**Case Fan** | [Corsair Air Series AF140 Red 66.4 CFM 140mm  Fan](http://pcpartpicker.com/part/corsair-case-fan-co9050017rled) | $16.98 @ OutletPC
 | | **Total**
 | Prices include shipping, taxes, and discounts when available | $1087.84
 | Generated by PCPartPicker 2014-12-20 17:40 EST-0500 |
https://linustechtips.com/topic/273824-first-build/#findComment-3719587
ok so last one:
Type|Item|Price
**Video Card** | [EVGA GeForce GTX 970 4GB ACX 2.0 Video Card](http://pcpartpicker.com/part/evga-video-card-04gp42972kr) | $329.99 @ SuperBiiz
 | | **Total**
 | Prices include shipping, taxes, and discounts when available | $1133.84
 | Generated by PCPartPicker 2014-12-20 17:51 EST-0500 |
https://linustechtips.com/topic/273824-first-build/#findComment-3719647
