Sup.
This will be very personal experience badly written review because i am not audiophile and i dont own audiophile grade equipment but i really like good sound to my ears.
As i was searching for good earphones ( never buy something you dont read review on because its waste of money the moment you do it - like my parents who bought other earphones than I asked for :I ) and among some options kindly provided on this forum i decided to get Nuforce 600x because it was readily available in my country.  Thanks everyone ^^ Great forum.
Mind you if you are searching for best sounding earphones, there are better/different options ( sony mh1, brainwavz delta, soundmagic e10, xiaomi piston etc...)
Whats the sound like?
Good bass, its often regarded as basshead earphone on the interwebz but its nice to have bass allready without needing to EQ. Really satisfying thump. Tho it becomes main part of the song here. Not everyone will like that, and for my liking its just a little bit too much.
https://www.youtube.com/watch?v=TzNm_FheZ3s
Also, i like rumble(or whatever is low-bass called) it produces at 3:00 onwards its really satisfying.
Mids can hide away.
Edit: highs are ok. Just dont remove filters :D Else they become piercing.
You can listen to this earphone on low volume. Despite its good seal and isolation I found that riding on a bus i wasnt enjoying music, but its listen-able. It wont block out much rumble from bus engine but it will seal well from talk. If you are bored on bus its ok but if you wanna enjoy music at normal listening levels its a no-go at least to me.
Is this headphone great? No, but its good.
My search for good sound equipment begins, but theese earphones will satisfy my need for portable sound. I will try to play around with eq.
https://linustechtips.com/topic/273547-nuforce-600x-review/
I don't think any passive isolation will block out bus done. That noise basically passes through your body to your ears
https://linustechtips.com/topic/273547-nuforce-600x-review/#findComment-3716789
