Hey guys
So I recently just got the GTX 970 that I upgraded from my 7770. Anyway I'm having an issue while opening games. for whatever reason when I open a game the screen goes black and I have to turn off my monitor and turn it back on for the game to show up.
Is there any reason for this? What can I do to fix it?
Thanks in advance
https://linustechtips.com/topic/273409-loading-into-games-with-problems/
May be a driver problem. Did you completely uninstall the AMD drivers before you installed the Nvidia ones?
Did you completely uninstall AMDs drivers? If so, maybe do a clean reinstall of the 970 drivers, and if those don't fix it, try an older driver?
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
Hey guys
Thanks in advance
Are you running your games at your monitors native resolution?
The GeForce experience attempted to run them at some crazy resolution i disabled them from doing that but it started happening ever since i got the geforce experience. I'm currently using HDMI because my Displayport Cable isnt in yet. Should i try removing the geforce experience and see what happens then?
Play games in borderless windowed mode if all else fails.
I use a Lenovo T440: i5 4300U, 8GB RAM, 128GB Samsung 840 Evo, 14" 900p display and an external 23" 1080p passive 3D monitor. Extended 6-cell battery with internal 3-cell. Ubuntu 14.04 LTS (I only use open-source software -- haven't paid for a single program yet).
