best midi tower case
Go to solution Solved by WoodenMarker,
Sorry for the late reply--I've been a bit busy.
I'd suggest going with a s340: https://www.komplett.dk/nzxt-s340-midi-tower-sort/824761
or sacrificing some airflow by going with the H440 if you need front drive bays: https://www.komplett.dk/nzxt-h440-midi-tower-hvid/807125
if you dont have a budget, go for fractal design r5
if you do have a budget under $80, go for nzxt s 340.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/273363-best-midi-tower-case/#findComment-3712215
Most atx cases have space for that. It would help to know what you're looking for in a case as well as where you're shopping/located, budget, and what model of graphics card/motherboard you have.
https://linustechtips.com/topic/273363-best-midi-tower-case/#findComment-3715598
Yea ok sry.
Basicly i need a atx case for a z97 and a gtx 970  and then i want to be able to mount a Corsair H110 with the radiator on the top of the case.
I also would love to have a window on the side.
and if possible a single ssd bracket on the buttom or on the back
https://linustechtips.com/topic/273363-best-midi-tower-case/#findComment-3716775
Yea ok sry.
Where are you shopping/located? Budget?
https://linustechtips.com/topic/273363-best-midi-tower-case/#findComment-3717107
Love my Corsair C70 Vengeance Mid Tower
Project Gray Scale
Intel Core i7 6900k @ 4.2Ghz - Dominator 32GB DDR4 2400 CL10 - Samsung 970 EVO+ 1TB NVMe - 2 Samsung 840 EVO 1TB (Gaming and Sratch) - 2 Barracuda 2TB
Asus x99 Deluxe - MSI Aero OC GTX 1080Ti - Seasonic 760 XP² - Mod1PC Custom Cables - EKWB CPU & GPU Blocks Nickle/Plexi - EKWB D5 PWM
EKWB PE360 - Corsair ML120 (6)  - InWin 303- NK65 Entry Watermelon w/ Gat Laseron 70g (205g0 & Filmed) - Logitech G Pro x Superlight
Kanto YU2 - Sennheiser PC360 SE - Acer XF270HU
BUT DOES IT FOLD?! https://folding.extremeoverclocking.com/user_summary.php?s=&u=963814
https://linustechtips.com/topic/273363-best-midi-tower-case/#findComment-3717266
Im from Denmark, If i cant get it here i'll try to find it in germany or UK.
My budget is around 200 dollars ;)
Are there any PC shops in Denmark you use that you can link us to?
https://linustechtips.com/topic/273363-best-midi-tower-case/#findComment-3720062
Yea there are a few ;)
https://www.komplett.dk/k/kc.aspx?bn=10149
http://www.computersalg.dk/produkter/220/kabinetter
http://www.proshop.dk/Kabinet.htm
really appreciate the help btw :3 .
https://linustechtips.com/topic/273363-best-midi-tower-case/#findComment-3720413
https://linustechtips.com/topic/273363-best-midi-tower-case/#findComment-3731044
