I am planning on building a PC that can run games smoothly preferably at 1080p and also can run Adobe Premiere, After Effects, Cinema 4D and programs like that smoothly and will not lag or glitch up while editing.
I am on a budget of 500$ so please choose accordingly.
If some gaming performance has to be sacrificed, I'm down with it. It also has to be a 64-bit system since all adobe products are mostly 64-bit.
I prefer price over performance but not in a significant amount.
Thank you,
Balaguru Raghupathi
14 year old with good grammar
https://linustechtips.com/topic/273246-new-pc-build-help/
You think that we are wizards? (I'm assuming you're from India) you have parts 40-50 bucks expensiver!
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($96.69 @ OutletPC)
Motherboard: ASRock 970 Pro3 R2.0 ATX AM3+ Motherboard  ($57.98 @ Newegg)
Video Card: XFX Radeon R9 270 2GB Core Edition Video Card  ($129.99 @ Newegg)
Total: $456.48
Generated by PCPartPicker 2014-12-19 15:17 EST-0500
If you get a r7 250 and a fx 4300 you might fit a ssd in
https://linustechtips.com/topic/273246-new-pc-build-help/#findComment-3709816
