Blank screen when waking computer up- is it a GPU problem?
Solved by QueenDemetria,
I am wondering if this issue is with the GPU or not.
When I wake my computer up from sleep after the display turns off but before full sleep, all that is displayed is a blank screen. The only way to fix this is to restart the computer.
So far, I have disabled hybrid sleep and ran the system file checker. Neither worked.
The problem went from happening once in a while, to happening quite often, to happening every time.
Is this a problem with the GPU, is it fixable?
Probably a driver issue. What GPU is doing this?
