I have a buddy who is looking to purchase a new pc for content creation.  He is going to be using for drawing and animation mostly.  He is not going to be making super pro level work.  Small independent projects nothing to crazy. He might be getting a Cintiq monitor in the future. His budget is around 1000.  I build this for my self recently. If I remove the i5 for an i7, Remove both videocards and add R9280x,  No need for windows key or monitor he has that already. Would that be enough or is there another route to take?
Off topic how do I search the forums? I have tried looking for a way but I can not find it at all.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.98 @ OutletPC)
CPU Cooler: NZXT Kraken X31 69.5 CFM Liquid CPU Cooler  ($69.99 @ NZXT)
Motherboard: Gigabyte GA-Z97X-UD5H ATX LGA1150 Motherboard  ($169.99 @ Micro Center)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($94.99 @ Amazon)
Video Card: Asus Radeon R9 280 3GB DirectCU II Video Card (2-Way CrossFire)  ($194.99 @ SuperBiiz)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer  ($16.95 @ OutletPC)
Operating System: Microsoft Windows 8 (OEM) (64-bit)  (Purchased For $0.00)
Total: $1465.03
Generated by PCPartPicker 2014-12-18 08:35 EST-0500
https://linustechtips.com/topic/272469-building-a-pc-for-content-creation/
What kind of animation work is he doing and at what scale? What programs are being used?
What else is the system being used for?
Is an optical drive really necessary?
Spend the extra 2 dollars on the asus optical drive.
..Why?
The pc above I build and purchased already for myself. As to why I bought the R9 280 I purchased them when it was going to be a cheap pc for myself.  If I would waited I would have purchased something else.
I was just using what I have bought to see if it was enough for him to use it has a Photoshop pc doing a lot drawing to start with. He is going to experiment with animation nothing heavy, very small things.  He mostly will be using this pc as a media pc not a gaming pc
From the list above I would remove:
optical drive
cooler
One or both videocards
Windows key
So the questions is should i use what is left and add a i7 instead of a i5?
Should I replace both video cards or just one?
A better cooler?
Or is there another path that I can go in with.
optical drive
cooler
Windows key
A better cooler?
Now that you say that, I'd get a gtx 970 (or 2 if you want to spend that much) and an i7-5820k.  For this kind of work, more cores is more.
It would help to know what other programs are being used. Animating with Photoshop really only needs any half-decent graphics card and some ram.
Some examples could be helpful.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
CPU: AMD FX-8350 4.0GHz 8-Core Processor  ($169.99 @ SuperBiiz)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($61.98 @ OutletPC)
Motherboard: Asus M5A99X EVO R2.0 ATX AM3+ Motherboard  ($118.99 @ SuperBiiz)
Memory: G.Skill Sniper Gaming Series 16GB (2 x 8GB) DDR3-1866 Memory  ($120.98 @ Newegg)
Storage: Sandisk X110 256GB 2.5" Solid State Drive  ($89.99 @ NCIX US)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($97.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 760 2GB ACX Video Card  ($199.99 @ Best Buy)
Case: Fractal Design Core 2500 ATX Full Tower Case  ($50.99 @ SuperBiiz)
Power Supply: SeaSonic 520W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($68.99 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.75 @ OutletPC)
Total: $993.65
Generated by PCPartPicker 2014-12-18 16:45 EST-0500
