Case light modding?
Solved by Mujteba,
As far as I know behind the front panel there should just be an LED for that power button. Either the LED itself is red or there is a red filter over the switch. For the former case, remove the red coloured LED and buy your desired colour of LED from the hardware and solder it place (check and triple check the polarity before soldering). If it turns out that it is a white LED and they are simply using a colour filter then take some sandpaper and see if you can make it clear so the light comes out white, then paint over it with transparent plastic paint of your desired colour.
