PSU Wattage PLEASE HELP
Go to solution Solved by KRImSIN,
650w is just fine. If you get SLI then get 750w or 800w.
Hello i need your guys help
which one of these power supplys will be enough
this is the system i will be building: http://pcpartpicker.com/p/xj48yc
these are the power supplys i am thinking about using
500 W psu: http://www.newegg.com/Product/Product.aspx?Item=N82E16817171098
650 W psu: http://www.newegg.com/Product/Product.aspx?Item=N82E16817171097
750 W psu: http://www.newegg.com/Product/Product.aspx?Item=9SIA0ZX2C70584
https://linustechtips.com/topic/271740-psu-wattage-please-help/
Cpu:
Intel i5 4460 Motherboard:Msi Z97S Sli krait Ram:HyperX Fury White (2x4) Storage:Seagate 1tb/Samsung 850 Evo 120gb Gpu:Gtx 960 2gb sc Case:S340 Black Psu:Corsair Rm 650w 80+ Gold certified
My anime list : http://myanimelist.net/animelist/KRImSIN
https://linustechtips.com/topic/271740-psu-wattage-please-help/#findComment-3686444
I don't know anything about these  power supplies but the most important thing is your system that will use it. Chances are you won't need anything more than a 450w unless you are doing an sli system.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/271740-psu-wattage-please-help/#findComment-3686454
