My power supply is 500 watts. I Don't know which form it is but the last time I opened my computer I took pictures and the model number is "DPS-500AB-B A". The power supply is made by Delta Electronics.
I want to get a power supply with at least 600 watts, semi modular at least, and somewhere in the range of 40 to 70 dollars. Also It should be a well known brand like Corsair or EVGA.
The reason why I'm upgrading is because I haven't seen a jump in performance since I've upgraded my gpu from the gtx 760 to the gtx 780. I looked on Nvidia's website, and It said that the Minimum Recommended System Power for the 760 is 500W, and the Minimum Recommended System Power for the 780 is 600W. So I'm hoping this upgrade will give me the performance boost I was looking for. Also I've been hoping, for when I have the money, to buy a gtx 980, and have my 780 and 980 in a SLI configuration. Do think that is possible???
https://linustechtips.com/topic/271557-help-upgrading-power-supply/
http://www.ncixus.com/products/?usaffiliateid=1000031504&sku=97531&vpn=110%2DB2%2D0750%2DVR&manufacture=eVGA&promoid=1416 its an amazing power supply
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
Delta make pretty solid power supplies, this one also happens to be 80 certified. You'll be fine without having to upgrade the current PSU for an upgrade to a GTX 780.
It's not possible to SLI a 980 and a 780.
The reason Nvidia recommends a 600W is if someone buys a complete lemon of a power supply it'll still work.
If you are set on upgrading though the power supply recommended by themaniac is very good for the price.
Andrew900460 make sure to follow your own topics so you get notifications when people reply.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
The b2 isn't as good as the G2 as far as I know. I presume its still pretty good though.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
it is but the g2 is not in his budget
Just making sure you were aware, some people get them mixed up, go on recommending something that isn't what they believe it is.
I apologize for the confusion.
i now which is which and the b2 is made by the same people who makes g2
Its just not gold rated, I know.
Alright thanks, I'll look into this power supply
Oh, and do you know if it has the same form as the one mine might be, I can't find any information on my PSU's form. If you want I'll try to attach the pictures of my power supply. it's only the one side with the stickers on it. Well, there is one picture that shows the other face with the fan, but that just shows the entire inside case.
