Hey guys. Was wondering if anyone would know we're I can get a custom side panel for the aerocool xpredator. I love the case but the cut-outs for the fans on the side are ugly and I want to just have a normal window were I can see the inside of the case with no problem.
And if anyone thinks this would be a bad idea as it will be bad for my systems cooling, and that I should just put the fans, please tell me because I don't want to damage my components.
Here's a pic of the side panel. :D
post-26798-0-38787100-1371416838_thumb.j
ASUS RTX 2080 Super ROG STRIX | AMD Ryzen 9 3900XT | ASUS ROG STRIX X570-F Gaming | Corsair Vengeance PRO RBG 16GB 3600MHz | NZXT Kraken X73 | Lian-Li PC-011 Dynamic | x9 CoolerMaster MF120 Halo
https://linustechtips.com/topic/26906-aerocool-x-predator-side-panel/
you could probably make on yourself just get some plexi from your local hardware store like home depot should be pretty easy, and provided you still have other fans such as in the front and whatnot then you shouldnt need to worry about airflow at all :)
About the airflow, you have a 200m intake fan at the front right and a 200m exhaust fan at the top? You could change the rear fan into an intake if you want to change pressure. Obviously your temperatures would be higher without the extra 200m fan, but you wouldn't "damage" your components.
"And yet my mind is screaming, provoked in an icy sweat. It’s pleading and begging for a release, scraping the walls of a padded cell, pounding hopelessly at the floors that won’t even deliver the gift of pain."  - Why I Don't Dream Anymore
Just cut a piece of clear acrylic (plexi) to the same shape but about 20mm larger all round the edges, push the window out, put some rubber u-channel on the edge and then stick the clear acrylic to the inside of the case with double sided tape (some of that 3m super strong mounting stuff). check out mnpctech i think he has a guide for this.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
Ok thanks for the reply's. I will just do it myself. Thanks guys :)
People make it seem like everyone can make their own side panels. Not everyone has the tools, my parents are pushing themselves and after a year and could finally make a pc. God knows what they would think if i asked for plexi glass.
Listen if you care.
  • 2 years later...
-SNIP-
I'd recommend to silicone it in place if you want a zero clearance where there is no gap between the plexi and the panel compared to double stick tape.
what are the screws i need if i want to stick it outside of the panel?
Are you suggesting to install it on the outside?
I guess you could but the inside would look a lot cleaner.
i saw a guy on youtube put it outside, ge did a great job, he dont need any new scews at all, he just use old scews that came in with the case which hold the acrylic
Link is here:
LinuxSexTips        :wub:
Link is here: -https://www.youtube.com/watch?v=FiXmUqCPmvE-
That doesn't look too bad actually.  :)
