So guyz i bought R9 270x on Black Friday sale and i also get psu and headset but my question is.
Is ther a cheaper way to connect my R9 270x with my laptop (lenovo G550) its the only pc i have tho.
Now im saving money for building pc with that R9 270x i set the parts but i wonder if i can use it
with my laptop i saw how its done with eGPU cabble but i dont think im spending 100 $ on cabble for
4-5 mounth in fact i need 450$ to finish my build. So finaly the question is "Is ther a cheaper way doin it"
:rolleyes:
The parts that im buying
CPU: Athlon 760k
Motherboard: ASROCK FM2A58M-HD+
RAM: 8 Gb 2 sticks on 1600 from A-DATA
Monitor: Asus 21.5 VS228NE
HDD: 500Gb
I live in Bulgaria so that will cost me about 700 lv but 1 $ is 1.5 lv :)  hope u can help me
https://linustechtips.com/topic/268872-connecting-gpu-with-laptop-help/
:rolleyes:
CPU: Athlon 760k
HDD: 500Gb
There is no easy way of connecting a gpu to a laptop ( yes with some modding and expensive parts)
 Just save some money and wait.
For those who are wondering yes it's possible http://www.hwtools.net/Adapter/PE4H%20V3.2.html
You should be able to if your laptop uses a pcie Wifi card.
-Just checked, Yes it does.-
Buy one of these and you can use it
http://linustechtips.com/main/topic/134657-mini-pcie-egpu/
Btw Mini PCIE only funtions as a 1X slot. Sooooo.... Bottlenecks.
A riddle wrapped in an enigma , shot to the moon and made in China
