Will a sata II port bottleneck my ssd or will i get full speeds.  I don't see why I would get a bottleneck because Even the highest quality of SSDs can do like 600 mbps read/write, but let me know if im wrong and why
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/267745-sata-ii-help/
It will bottleneck a little...That being said I do not notice it on my computer.
Its still well worth the price of the ssd even with the small bottleneck. SSD is still the best thing I added to my computer could not live without it.
CPU Ryzen 5 Asrock B350 Pro 4 / MSI RX580 Gaming / RAM 16 Gigs Corsair Vengeance 3000 / HDD 1TB Seagate Barracuda / SSD Samsung 840 120GB / 500GB Samsung SSD / Case Urban S31 / PSU EVGA G2 750w / Os Windows 10 / Keyboard Corsair K70 / Mouse Razer Naga 2013 (Won it from Linus!!
https://linustechtips.com/topic/267745-sata-ii-help/#findComment-3635826
SATAII gets 300MB/s(give or take). SSDs go far and beyond that, so yes your SSD will get bottlenecked.
https://linustechtips.com/topic/267745-sata-ii-help/#findComment-3635831
Sata 2 WILL bottleneck an SSD. Sata 2's max speeds are 300mb/s, so it would be limiting an SSD
CPU: AMD FX8350 @4.4GHz | MOBO: ASUS Sabertooth 990FX R2.0, 990FX chipset | RAM: 16GB (4x4) dual channel Patriot Xtreme series DDR3 @1866MHz @1.65V | GPU: Asus Radeon R9 Fury Strix| PSU: Corsair AX860i 860 watt | CPU cooling: Noctua NH-D15S + additional Noctua NF-F12 | Case:Corsair C70 Black | Storage: 3x 128GB Samsung 840 pro SSDs; 1 for the OS, 2 in RAID 0 for games. 3x WD Red 3TB HDDs in raid 5 for bulk storage | Displays: 1x Dell 3007WFP 30 inch 2560x1600 IPS LCD. 1x I-Inc IH253DPB 25 inch 1920x1080 TN LCD | Keyboard: Corsair K70 with Cherry MX brown switches + Blue LED backlight | Headphones: Sennheiser HD 280 Pro | Mouse: Logitech G600 @1100 DPI | OS: Win 10 Pro 64 bit |
Mfg/model number: Clevo/W355SSQ | CPU: Intel i7 4710MQ @3.5GHz  | MOBO: W35xSS_370SS, HM87 Chipset | RAM: 16GB (2x8) dual channel Crucial Ballistix DDR3 @1866MHz | GPU: GTX860m 2GB Gddr5 | Battery: 76,960mW/h 8 Cell battery, 3 Hrs full on a full charge | Storage: 1x 128GB Samsung 840 pro SSD for the OS. 1x WD Red 1TB HDD For storage and games | Displays: 1x 15.6" 1080p LCD | Keyboard: Full 103 key back-lit keyboard | Mouse: Logitech M510 | OS: Win 10 Pro 64 bit |
https://linustechtips.com/topic/267745-sata-ii-help/#findComment-3635836
This is why proper capitalization is required when it comes to data unit sizes.
https://linustechtips.com/topic/267745-sata-ii-help/#findComment-3635846
i did proper capitalization for the speeds.. didn't i? mB with a capitol B is bytes, a lowercase b is bits, correct?
https://linustechtips.com/topic/267745-sata-ii-help/#findComment-3635863
@littlepigboy5 Yes and no. It will bottleneck large data transfers for sure but when you pc needs to read something from the drive it will 9/10 times really on IOPS speed, which isn't even close to as fast as sequential performance. I think it's still very much worth it. Just get something super cheap like an m500 from crucial. Dirt cheap and yet very fast. They were 85 for a 240gb on amazon in america last I checked.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/267745-sata-ii-help/#findComment-3635899
Yes, but you typed mb. SATAII does 300 megabytes per second. Not megabits.
https://linustechtips.com/topic/267745-sata-ii-help/#findComment-3635909
oh... crap.. lol sorry you're right. i was thinking of 3Gb (gigabits) per second.
https://linustechtips.com/topic/267745-sata-ii-help/#findComment-3635926
