Help with CPU + GPU for 21:9 Display
Hi All,
Looking for some advise on what components to use for a build that can play games at max settings and 2560 x 1080 resolution. I have read (though I have not seen data) that a 1080p 21:9 resolution only increases load at about 15% compared to a 16:9 1080p setup. Based on this I would assume that a card like an R9 290 or a 970 GTX would last me many years.
The issue is that I have a limited budget (who doesn't!) I have read articles about CPU and GPU balance. In theory a 280x + i5 (4460) combo would be more "balanced" than a 970GTX + i3 (4160). I prefer the latter, partly because I find it cheaper to upgrade the CPU later on than the GPU. I am happy to give up FPS and achieve ultra game details as long as I am above 30 FPS (remember I am working with 1080p here).
My question is, is it really a bad idea to go with the i3 + 970GTX until I can upgrade to an i5 or i7? If so why? Can the i3 not give me FPS above 30 while I enjoy sweet graphics with the powerful GPU?
https://linustechtips.com/topic/267353-help-with-cpu-gpu-for-219-display/
Hi All,
Maybe go with the anniversary pentium if your planning to upgrade in the not so distant future just to save a few more dollars. That way you will be running the same socket so you can upgrade to a i5-4690k down the road   ;)
That is, if you don't mind the whole 'four core only' thing that games like Far Cry 4 are doing.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
Cool, thanks for your comments so far. I forgot to mention the type of games! I mostly will be playing single-player campaigns right now, so Dragon age inquisition, Shadow of mordor, witcher 3, Batman Arkham Knight, Assassins Creed, etc.
You need atleast a 970 buddy or a 290x :)
Im going for 3440 x 1440 21:9 monitor and a 980
"If Everton were playing at the bottom of the garden, I'd pull the curtains." - Bill Shankly
You all make pretty good comments, thanks for your suggestions! I will consider the anniversary pentium as a strategy to speed up a later upgrade. Also the 970 seems like a clear winner here. Any ideas about performance on ultra-wide monitors? It is much easier to find benchmarks for the typical 16:9 ratios.
